Old 15-Apr-2006, 17:41   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Front wheel spacer
Hello
Can somebody clarify which way round this spacer should
be for front wheel. Does this notch go LHS as speedometer drive plate.
Also do I need to greese the bearing before tapping them into the wheel.
many thanks in advance.
regards
TopiToo
Old 15-Apr-2006, 17:55   #2
Duke2BSteve Duke2BSteve is offline
Duke2BSteve's Avatar
If memory serves me right, it should go on the opposite side to speedometer drive plate. So that the locking nut which fits into that groove is on the other side, as the locking nut is on the speedo side. Hope thats clear, starting to confuse myself now?
Old 15-Apr-2006, 18:37   #3
Steve just checked 3 of my wheels one 3-spoke has it on the rightside (Non Speedo) where as another 3-spoke and a 5-spoke have it on the speedo side.
I haven't disturbed any of these but when I do swap bearings I put the notch speedo side
Old 15-Apr-2006, 18:49   #4
Bikes: 748ish . .
Hello
Thanks for the replys there is no info in the bible,
I will see which end the spacer is when I take my other front wheel off,
before tapping the last bearing in.
Does seem odd, its there for a reason I guess, maybe all will be clear in the morning.
regards
TopiToo
Old 15-Apr-2006, 18:50   #5
keefer keefer is offline
keefer's Avatar
its there so you can get the bearing out
like i did the other day for ya
Old 15-Apr-2006, 18:56   #6
It doesn't matter which way it's fitted. The notch is to drift one of the bearings.
Just make sure it's in square against the bearing
Old 15-Apr-2006, 19:08   #7
Bikes: 748ish . .
Hello
again thankyou very much one and all.
regards
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:09.
