Old 02-May-2006, 15:48   #1
TonyH TonyH is offline
TonyH's Avatar
Mood: Bits fitted service done, Nice
Termignoni Question 45mm 50mm?
I currently have a 748E 2001 model and I have been contemplating fitting a set of 45mm termignoni’s.
Will I need to change the ECU chip or will the standard fit chip still do the job, I’m a bit wary of messing around with the ECU, the last thing I want to do is screw the standard chip/housing and end up with expensive bill to sort it all out and/or a bike that runs like a Russian tractor.
The price of second hand termis seems quite good at the moment but with the addition of a new chip/second ECU and set-up costs it may well be a none runner.
I'm sure many of you have fitted them (mechanically a straight forward job) and changed ECU chips, so any info would be very helpful
Apart from the obvious pipe diameter whats the main difference between 45mm and 50mm pipes from a performance and suitablilty point of view?
[Edited on 5-5-2006 by TonyH]
Old 02-May-2006, 16:04   #2
m1keyp m1keyp is offline
Fitting is easy, be aware that the 748E and the 748S have different headers.
Although you say you want 45mm termis be aware of the above as 50mm will not fit standard 748E headers.
Old 02-May-2006, 17:26   #3
hogfisch hogfisch is offline
Mood: dooM
Fitted 45mm termis to my 748s and later changed the chip to a JHP one. The chip smoothed things out and didn't take much more than a few minutes to fit. Just be careful to earth yourself first before handling the ECU and make sure you don't bend the new chip pins over as they can be a bit fiddly.
Old 02-May-2006, 17:36   #4
TonyH's Avatar
So its just old chip out new chip in and off you go, nothing else?
Old 02-May-2006, 21:23   #5
deej deej is offline
deej's Avatar
yep but make sure you get all the pins in correctly, use a torch to check their all in correctly before starting her up. trust me on that 1 !!!
Old 02-May-2006, 21:31   #6
CipiVTS CipiVTS is offline
CipiVTS's Avatar
I have the original ECU for the 748 with 45mm termignonis. I 'm using the cans on my 916, so i don't need it...
I'm living in Romania so i don't know how can we make the deal... but if you have an idea, please advise
Old 02-May-2006, 21:32   #7
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
I changed my standard pipes for 45mm Termi's on my 748S. Didn't change the chip, runs sweet as a nut. 2 years later, no probs and sounds awesome.
Ade.
Old 02-May-2006, 22:24   #8
HUNT749 HUNT749 is offline
My 2000 748bp has 45mm termis and i checked the chip this weekend and it says casoli moto 748sps on it no idea if its the correct one but it runs ok tho......
Simon
Old 03-May-2006, 16:46   #9
Frank Frank is offline
Mood: got to be a worry.....!
Same with my 2000 748E, 45mm with a Casoli 748 SPS chip and has run fine. (hopefully not famous last words!).
A
Old 03-May-2006, 16:55   #10
hooley hooley is offline
hooley's Avatar
Mood: One day I'll be allowed out to play......
JHP ECU chips are about £30 if my memory serves me (which it usually doesn't)
Jas
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 17:36.
