Old 04-May-2006, 16:22   #1
B19PSK B19PSK is offline
Bikes: 998S and MTS1200S
B19PSK's Avatar
Mood: Growing old disgracefully, DSC member 2387
Mirror Indicators - 748 - 998
I recently purchased a set of these from Ebay.
The guy charged the earth, supplied duff bulbs then wanted to charge £15 each to replace them.
You can buy them from www.far.it
You do need to drill the faring and head frame (the bit that holds the top faring on).
Chuck the standard 5W amber bulb away – as it is about as much use as a chocolate teapot..
I’ve found a place on Ebay that sells 21W clear bulbs (10x2mm base wedge) – great if you want amber lenses.
If you want or have clear lenses I can supply these same bulbs, but painted with amber paint for £4.99 each, that’s £ 3 cheaper than anyone else.
Old 04-May-2006, 19:12   #2
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
hi - do you have a URL for the right page? the numbers in the mirrors list don't seem to correspond to anything intelligibly ducati related.
ta
Old 05-May-2006, 10:01   #3
B19PSK's Avatar
When I get home I'll look them up in the catalogue,
This is the link http://www.far.it/catalistinospecial...ORT%20748R-998
Or search in the main or specialist catalogue, 748-998 and the indicator mirrors all start 6xxx, on the main catalogue they now list LED indicator mirrors.
Hope this helps.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:27.
