Old 13-May-2006, 23:51   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Can I Use My Bike When One (or more) of the Clutch Springs is Missing?
Related to my "snapped thread" post.... (clutch spring bolt snapped in the post)
Is it possible/wise to use the bike with only 5 clutch springs fitted? Or maybe even just 4 if I remove the one on the opposte side to even the pressure up a little?
I remember reading somewhere on this ere interweb of someone who was riding round with just 3 springs.
It would only be a stop gap measure until i can have someone with a steady hand and a sharp drill-bit get the little bugger out. That would probably be a trip up to Tecmoto in a couple of weeks after my exams.
Advice needed for a clumsy numpty please
[Edited on 13-5-2006 by zhed44]
Old 13-May-2006, 23:56   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I've got no experience of this but, buggering things up further is only gonna cost you more...think on it.
Old 14-May-2006, 00:05   #3
zhed44's Avatar
Mood: YELLOW!!!
Originally posted by twpdis only gonna cost you more...think on it.
i dunno - if i use the car instead, then £8 congestion charge and £4 per hour for parking soon adds up
Old 14-May-2006, 00:09   #4
GsxrAge GsxrAge is offline
GsxrAge's Avatar
as long as the clutch does not slip you should be ok but get it fixed ASAP
Old 14-May-2006, 08:17   #5
misterpink misterpink is offline
Bikes: multistrada, 748R/916
misterpink's Avatar
Mood: one very coool cat!
i had a similar problem on my last 748 - a slow speed drop onto its side smashed the useless carbon cover and broke a spring/retainer. With the cover off and carbon bits cleaned out i limped from home to daytona near kings cross about 3 miles mostly in 2nd gear - it is not easy as getting the clutch to engage/disengage was not really happening so it was good timing and luck mainly. if you are AA member or something get them to take it to get it fixed daytona ot wherever is closest - riding it is tricky/possibly dangerous and do you need further problems?
Old 14-May-2006, 08:21   #6
Glyn Glyn is offline
Glyn's Avatar
Mood: st2......we can rebuild
take off the opposite spring,keeps it balanced
and its fine
Old 14-May-2006, 10:00   #7
FiscusFish's Avatar
I run my Superlight with 4 springs. Makes for a nice easy clutch pull. Haven't had any slipping despite a dozen or so trackdays like it, however the power my bike makes is considerably less than yours.
Old 14-May-2006, 10:02   #8
There's been many a trackday incident that has meant that a full compliment of clutch springs is unavailable - as long as you remove a single or an opposite pair it should get you home - I wouldn't recommend that it stayed that way for too long though.
Tim
Old 14-May-2006, 12:07   #9
yeti yeti is offline
yeti's Avatar
Ducati Corse have been running 4 spring slippers for donkeys years. Need I say more?
Old 14-May-2006, 14:19   #10
zhed44's Avatar
Mood: YELLOW!!!
thanks for all the advice.
looks like i'm going to keep riding it for a while, until it's fixed, but the remaining question is - do i remove the opposite spring or not?
BTW: luckily, the springs are brand new.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:59.
