Old 17-May-2006, 14:15   #1
desmobob desmobob is offline
desmobob's Avatar
Mood: Beige.....
Race shift pattern / 1-Up, 5-Down?
Could some helpful individual possibly disclose to me if it's possible to change the gear selection pattern to 1-up / 5-down on the 999R and 916 without purchasing additional bit's-and-bob's ?
On my R6 / R1 it's a case of just swapping the selector shaft upside down, not sure about the aformentioned Ducati models though.
Old 17-May-2006, 14:16   #2
khushy khushy is offline
khushy's Avatar
all you need is a race pattern lever - you can do it without one but the "feel" is aweful.
Do it - you wont look back!
Khushy
Old 17-May-2006, 14:30   #3
desmobob's Avatar
Mood: Beige.....
Many thanks, I'll put an 'ad' in the wanted section
Old 17-May-2006, 14:35   #4
desmobob's Avatar
Mood: Beige.....
Forgot to ask, is that the same for both the 916 and 999R ?
I would have thought the 999R would have allowed me to change the pattern without any additional cost .... but then it is a Ducati
Old 17-May-2006, 14:39   #5
khushy's Avatar
yep - the same!
Old 17-May-2006, 14:41   #6
I've got the reverse shift lever on my 998R and I run reverse shift on the racebike as well but Grahame (Butch890 on this board) just turned the bugger around somehow so it still has the linkage.
It is a different feel with the direct lever off the spline as opposed to using the linkage to achieve the same pattern.
Old 17-May-2006, 15:44   #7
apparantly butch used a crank lever off of an 05 monster £10! to achieve the race pattern with the linkage lever!
Old 17-May-2006, 15:51   #8
Herb Herb is offline
Khushy
Can someone explain to me why there is a difference between road and track set ups and what the advantages are. Not a racer, just curious.
Old 17-May-2006, 16:01   #9
ziggi ziggi is offline
ziggi's Avatar
Herb - You're probably thinking that it's more logical to go up the box to go up a higher gear and down to go down a gear but in race mode, pressing down on the lever to go up a gear is quicker and slicker to operate. Imagine a race bike with a quick-shifter and race pattern just holding open the throttle and ust pressing down every few seconds for maximum velocity. If you watch the racers when they click up (to go down a gear) they normally do 2 or 3 gears at a time to get it out the way and right for a corner.
Old 17-May-2006, 16:02   #10
Khushy
because operating the lever with your foot is easier pressing down than getting your foot underneath to lift it, when there may be ground clearance issues.........eg if you have to change gear when leant over its more likely that your doing this accelerating, ie, going up the box rather than down....
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:42.
