Old 21-May-2006, 16:32   #1
m1keyp m1keyp is offline
Internal Oil Filter
Just in the process of changing the oil and the small filter bit (not the cartridge) won't come out.
Am I right in thinking it should just pull out or is there a trick to its removal?
Any advice is welcome
Old 21-May-2006, 16:33   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
You mean the gauze filter? Well you should just unscrew it out of the cases and then all you need to do is wash it clean in petrol/paraffin.
Old 21-May-2006, 16:34   #3
This is the one with a cap,
unscrewed the cap and there is the gauze filter, does that unscrew aswell?
Old 21-May-2006, 16:37   #4
Hmmmm.....sound nothing like mine. Photo? O perhaps Wilf on here can help?
Old 21-May-2006, 16:39   #5
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
Its Normally attached to the plug end . 4D
Old 21-May-2006, 16:41   #6
Ducati Dealer
wilf's Avatar
yeah , if it's a later type (MY200 onwards) you unscrew the cap (large allen key) and then the filter needs to be unscrewed also (same size allen I think) then it slides out, give it a clean (but have a good look at what's on it first, it's good chance to see the state of your motor)
Worth replacing the alloy washer that's between the cap and cases, they are about 10p so not worth reusing.
good luck.
Old 21-May-2006, 17:02   #7
So it does unscrew
Its a 2002 748S
Thanks for everyone's help.
Mike
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:43.
