Old 06-Jun-2006, 15:04   #1
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
Rear Brake why are they a bit pants?
Is it a case of they all do that sir or something else.
Its a 02 748 with 6k, I've not bleed the brake or changed the pads and as far as I know the pads not contamintated? There just well pants imho.
Old 06-Jun-2006, 15:18   #2
weeksy2 weeksy2 is offline
yup, they all do that....
don't bother with it... use your feet, it works better
Old 06-Jun-2006, 15:24   #3
Fordie Fordie is offline
Regional Organiser - BHCN
Fordie's Avatar
Mood: Raring to Ride
There's been a few reports of rear brake "disappointments" all i can say is the more you use it the better it works. I ride a 996 I can by using only the rear brake drop down from 90 to 40 fairly quickly before tipping it into a bend. Im sure, that because its a taboo not to use the rear brake ( beat's me why) people refuse to use it ,then find it dont work cause the pads are cover in muluk . Take out the pads give em agood abrasive rub over , bleed the cylinders if posible, then go out and try using only the rear brake . Im sure Brembo would not cock up and fit a rear brake that was not designed to work efficiantly. 4D
Old 06-Jun-2006, 15:25   #4
Ray Ray is offline
Ray's Avatar
You can make 'em better for while by bleeding or new pads if they are well down but they slowly deteriorate again over time.
All sorts of theories for this from master cylinder/fluid reservoir too near the exhaust, shite from the chain getting on the disc/pads, the caliper is upside down by design so difficult to bleed properly etc, etc.
Ray.
Old 06-Jun-2006, 15:28   #5
Martinp's Avatar
Mood: 748ish
Ho Hum then, I think i'll just use the funny dinner plate things on the front wheel or me feet.
Old 06-Jun-2006, 15:33   #6
NormanBurrows NormanBurrows is offline
Bikes: MS1200S, T150V
NormanBurrows's Avatar
Mood: Hopeful
Mine's the same but responds to a good cleaning (pads and pistons) and deglazing by dragging the brake for a hundred yards or so with the throttle on.
I suspect Ducati didn't want it too strong because, when you're hard on the brakes with all the weight over the front, the slightest touch on the rear pedal will have you backing it in like Nicky Hayden.
Safe riding.
Old 06-Jun-2006, 15:41   #7
rcgbob44's Avatar
I was going to fit one of the rather tasty 4 poy rear calipers on my 998 till I saw how much they cost, I think I`ll try a pad change first of all, but yes there all crap.
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 06-Jun-2006, 15:46   #8
m1keyp m1keyp is offline
If you plan on bleeding them regularly the swap the nipples for speed bleeders.
http://www.speedbleeder.com/
Delivered from the states in days and brilliant!
Old 06-Jun-2006, 22:27   #9
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
^^^^ wot he said.
i use the rear all the time and although the fluid looks like coca-cola it has given me many miles of trouble free, enjoyable and safe motorcycling
Old 06-Jun-2006, 23:16   #10
Martinp's Avatar
Mood: 748ish
Nearly shot into the back of a car tonight so will be stripping down at the tomorrow on my split.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:40.
