Old 15-Jun-2006, 15:10   #1
smilo006 smilo006 is offline
smilo006's Avatar
Mood: I like my bike
Question marchesini magnesium wheels
http://cgi.ebay.co.uk/Ducati-Magnesi...ayphotohosting
do you need to be careful about which model etc that mag wheels will fit, if the wheel is a std one and not a racing mag wheel? (996R)
Old 15-Jun-2006, 15:13   #2
weeksy2 weeksy2 is offline
to an extent yes.... however the number of large hub wheels is fairly remote..
Old 15-Jun-2006, 15:19   #3
desmobob desmobob is offline
desmobob's Avatar
Mood: Beige.....
Often magnesium wheels aren't fitted to factory built race rep's for the road (like the 999R / 749R) - as they're not as resiliant as forged aluminium wheels when they hit big road debris. I've wondered how Ducati are getting away with fitting Magnesium wheels to the new Desmo Moto-GP rep bike. Also check rim diameter, or you'll end up having to buy race tyres and run them on the road ... unless it's for a racae bike that is
Old 15-Jun-2006, 15:38   #4
Yes, you do need to be careful about fitting mag wheels. I'm not sure whether your question is whether race wheels will fit a road bike? In that case the answer is most often no - they may be 16.5 inches diameter or need forks and yokes that have a wider track or brakes with a different offset as I understand it (although someone who really knows their race bikes might be along in a minute).
If your question is about 'are there any road bikes that roadsized mag wheels are not suitable for' the answer is yes...you wouldn't want to fit mag wheels on a Bip because they're not designed to take the weight of two-up riding - although obviously OK if you've got a single seat conversion.
I'm dubious about secondhand mags anyway. Magnesium alloy doesn't like water very much and has an alarming tendency to turn back into crumbly white powder, so manufacturers use a special chromate primer and then paint to try and keep corrosion at bay, but you have to keep right on top of any dings or scratches on your wheel otherwise corrosion can start to work it's way under the finish. Most manufacturers advise getting mag wheels x-rayed for corrosion or stress fractures once a year and advise you to get them refinished if there are significant scratches (since these are not just cosmetic). Companies like Dymag will refinish mag wheels, for a price, but my understanding is that if they find any defects when they x-ray them, they'll just cut them up no questions asked rather than take a potential law suit when your wheel crumbles to magnesium oxide beneath you.
___________^
Old 15-Jun-2006, 19:48   #5
Lily Lily is offline
Mood: stiff and tired
I have just got mine back from Dymag and they ahve done a great job with them... very bling
Old 15-Jun-2006, 20:24   #6
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
lily,
Did Dymag re do you Marchies? I'd like to get mine done profesioanlly this winter. Mind if I as how much. U2U me if you like.
Thanks, Rob
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:29.
