Old 28-Jun-2006, 18:50   #1
jon_m3 jon_m3 is offline
yoke help
ive just bought a nice set of forks off a 748 that has the adjustable rake on the headstock and the larger bottom yoke, will these go straight into my headstock non adjustable type 748bp?? or will i have to use my bottom yoke?
Old 28-Jun-2006, 19:56   #2
Mood: Come on spring!!!
The only reason it will have a bigger yoke is if it is for the ohlins forks!! Otherwise the yokes will be the same as yours! Fit straight in.
Old 28-Jun-2006, 20:24   #3
the bottom im sure is larger, ill post some pic tomorrow cheers
Old 28-Jun-2006, 21:10   #4
keefer keefer is offline
keefer's Avatar
as said I think the yoke is the same
its the hub it sits in that is adjustable.
and as such I hope your head stock is large enough to except it
if the internal diameter of the bottom yoke is larger then it is for the ohlins forks.
Old 28-Jun-2006, 22:08   #5
The bearings are different as well, so that will be another problem.
Chris.
Old 28-Jun-2006, 23:11   #6
ok heres a pic its abit **** the bottom yoke is larger than the standard ones on my baike
Old 29-Jun-2006, 11:17   #7
dave996 dave996 is offline
dave996's Avatar
Mood: Fed up...
It should fit, but if in doubt swap the bottom yoke for your original and sell me the other yoke
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:44.
