Old 02-Aug-2006, 22:52   #1
Cris Cris is offline
Cris's Avatar
Mood: I'm off
Unhappy seat pad screw
took the bike out yesterday for a quick blast, and after about 20 minutes into the ride, i felt the back pad start to fall off. i didn't manage to catch it in time, and it fell off. i went back and found the pad, but unfortunately it had been run over several times. it was completely ripped and the screw gone. anyway, i am planning to get the pad re-upholstered, but i still need the screw. does anyone know whether the D clip screw is replaceable?
Old 03-Aug-2006, 00:28   #2
yellow916 yellow916 is offline
Cris
I assume you've tried the obvious - a Ducati dealer? Failing that, have a look at the Dzus web site (http://www.southco.com/landingpages/dzus/).
If you need someone to recover the seat pad, I can recommend RD Designs, 2Milne Walk, Hartlepool, TS25 3RQ. They did an excellent (and quick) job on mine when I wanted a thinner one made up.
HTH
Andrew
Old 03-Aug-2006, 14:24   #3
philthy philthy is offline
philthy's Avatar
Mood: Can't make me mind up
Cris
I think they are about £40 from a dealer....The same thing happened to mine but I lost the pad too. I got one off ebay but with postage etc. only saved £5 off the dealer price. Haven't got round to sorting the clip out yet.
Old 03-Aug-2006, 17:08   #4
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
The screw is/was recently available do you need a part number?
Rgds, Rob
Old 14-Aug-2006, 22:12   #5
Cris's Avatar
Mood: I'm off
sorry for the late reply. thanks for the info everyone.
Rob, yes please on that part number. I will take the pad to a local upholsteror tomorrow to see if they can do anything with it.
Old 14-Aug-2006, 22:19   #6
aka.eric aka.eric is offline
DU85040171A - Seat Pin.
£5.78 +vat JHP.
Old 15-Aug-2006, 13:15   #7
Cris's Avatar
Mood: I'm off
just called jhp, they've got both pad and pin in stock!! now on it's way to meeeee.
cheers all.
Old 15-Aug-2006, 14:11   #8
FiscusFish's Avatar
Out of interest how much was the pad?
Old 16-Aug-2006, 10:48   #9
Cris's Avatar
Mood: I'm off
around £45 + £6 for the pin. both arrived this morning. now all i have to do is get it MOT'd. ran out beginning of march.........Oops!!
the pin is just the pin though, no washer that stops it from falling off again. it's very loose. you have to get some sort of retainer to keep it in place.
Old 16-Aug-2006, 13:36   #10
bitchinSP4 bitchinSP4 is offline
I stck a strip of tape over the 'D' ring as a tempory measure about 5 years ago, its still there!!
Mike.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 15:44.
