General Motorcycles only
Old 26-Aug-2006, 13:29   #1
Mr C Mr C is offline
Whats the difference...
(Ignore the Arrows)
Whats the diffence Between these 2 clutch plates, 1's got a solid friction pad whilst the other has seperate pads.
Old 26-Aug-2006, 13:31   #2
CK CK is offline
wet clutch / dry clutch?
slipper v's std?
old v's new?
do they both work?
Old 26-Aug-2006, 14:00   #3
Sintered versus carbon?
Old 26-Aug-2006, 14:13   #4
MonstaTom MonstaTom is offline
MonstaTom's Avatar
as andy says, the left is standard (not sure wot it's made of) and the the right is a sintered.
I think...
Old 26-Aug-2006, 14:19   #5
That said i dont know what make, my sintered ones are seperate parts ie slotted.
Old 26-Aug-2006, 14:57   #6
khushy khushy is offline
khushy's Avatar
Wink I think you will find . . .
they are both Carbon - just different types of plate!
sintered plates have a golden colouring to them and are usually on steel.
Khushy
Old 26-Aug-2006, 18:19   #7
So is Sintered Better?? what difference will i notice to the Standard ones
Old 26-Aug-2006, 19:06   #8
Depends how much power your trying to put through them
Old 27-Aug-2006, 00:42   #9
The one on the left looks like a standard item, on a steel plate (try a magnet) and the one on the right is a Surflex carbon item.
The Surflex is an upgrade over stock. Higher friction material, so able to handle more HP. The Surflex pack usually builds with thinner steels so you can 8 or 9 plates in to increase the surface area of friction material to.
Old 27-Aug-2006, 09:20   #10
Founder Member
Paul James's Avatar
Yu da man Nelly, spot on as usual mate
http://www.multirole-eng.com
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 14:27.
