Old 29-Sep-2006, 12:28   #1
skidpan skidpan is offline
749 Ecu + Pciii For A 999
Hi
I'm upgrading my 749 to a 999 and I was wondering if the original 749 ecu could be used with a PCIII to run the 999. Hopefully I'll have a termi 57mm system and air filters to complement the engine.
Graeme
Old 29-Sep-2006, 12:31   #2
Ducati Dealer
wilf's Avatar
no chance.
The PC3 would be all you need to make your 57mm system work on the 999 with the standard ECU
I'm guessing you have the 57mm system from your 749 and now want to fit it to the 999?
What years are the bikes?
748RS race bike (well, 853 but who\'s counting!)
999S road bike,
www.motorapido.co.uk
Old 29-Sep-2006, 13:45   #3
Twinfan Twinfan is offline
Twinfan's Avatar
The PCIII can't change ignition timing, which I'm assuming is differnt on a 999 from a 749. The fuelling side would work, and if the PCIII could change ignition, then it oculd be possible. However, you would need a lot of dyno time to get the custom map. Not worth it, even if it was possible!
I would flog the 749 ECU and buy a 999 ECU. Keep the PCIII to map your 57mm system in.
Old 29-Sep-2006, 13:50   #4
I've got the 999 engine but nothing else yet, hopefully over the next couple months I'll purchase the termi's pciii and air filter + then dyno time.
Graeme
Old 29-Sep-2006, 18:27   #5
jhsracing jhsracing is offline
yes the motor will be fine with a 749 ecu and a power commander, but you will need a custom map to get it to run correctly.
jh
www.jhsracing.co.uk
Old 29-Sep-2006, 22:25   #6
Twinfan's Avatar
A custom PCIII map, or a re-mapped 749 ECU????
Old 01-Oct-2006, 13:18   #7
mapping
custom map on the power commander with the 749ecu fitted.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:05.
