Old 26-Oct-2006, 09:53   #1
katana katana is offline
Mood: Annoyed and confused
What size tyres do the DD bikes use?
Was told that alot of the DD bikes use 120/70 fronts instead of the 120/60
Was wondering why?
Old 26-Oct-2006, 10:02   #2
Was wondering why?
You get more tyre to use when the bike is on its side.
I ran a 120/60 at the start of last year and ran it off the edge and had a few front end slides. I changed to the 120/70 and the problem was solved.
It was AK who pointed this out to me, I would have just kept going thinking that it was fine!
Old 26-Oct-2006, 10:06   #3
ali ali is offline
ali's Avatar
Mood: Damp
120/70 creates a rounder profile (taller), so there is a greater contact patch when leaned right over.
Old 26-Oct-2006, 18:26   #4
Zimbo16 Zimbo16 is offline
Zimbo16's Avatar
Mood: Feeling peckish
Indeed, Dominic Clegg's high speed crash at Assen was caused by him riding off the edge of the 120-60 tyre he had fitted.
Old 26-Oct-2006, 18:55   #5
Jamcoly Jamcoly is offline
Jamcoly's Avatar
Mood: starting to feel better
I use a 70 profile on the road
even with the rear end jacked up
i had to drop the bike on the forks about 5mm
to get the front end feel back, because of the taller tyre.
Old 26-Oct-2006, 19:47   #6
Dominic Clegg's Avatar
use the 70 i used the 60 in first half of the season and ran out of tred at assen and had a big crash
Old 26-Oct-2006, 19:58   #7
ali ali is offline
ali's Avatar
Mood: Damp
Hate to contradict, but I don't suppose anyone in DD has ever ridden off the edge of a warm front tyre! Losing the front end can be caused by many things; too much braking/steering force, cold rubber, cold carcass and hot surface, too little suspension travel, too high tyre pressure, oil/coolant on track, debris on track, change in surface, etc, but the difference between a 60 and a 70 profile front is not going to help you in 9 out 10 instances.
The transition to a 70 profile front is only pretty recent for many racers (in other series) and people have been leaning other race bikes over a looooooong way for many years now without falling off the edge.
If you get the chance, try both. A 60 profile should give you a greater contact patch at the sort of lean angles you'll be riding in the wet, and a 70 should make the bike tip into corners a little easier (better in the dry). Given the state of our climate I wouldn't write one off in favour of the other just yet!
Cheers,
Ali
Old 26-Oct-2006, 21:30   #8
i was running to the edge of it. Any way when i put the 70 in it also helped the bike turn a lot faster
Old 26-Oct-2006, 22:08   #9
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
you can't argue with experience!!
Old 26-Oct-2006, 22:51   #10
domski's Avatar
I ran a 70 all last season, then we started this season on a 60 - coz thats what was fitted from the showroom. Did Cadwell, Brands and Assen trackday on it and didn't really notice any difference (forgot it was a 60 actually).
However, I prefer a 70 - even it's psychological.
A racers head is as important, if not more important than anything else on the bike etc.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:38.
