Old 04-Nov-2006, 20:44   #1
nigeeeboy nigeeeboy is offline
Milky Coolant in the Header
Odd one this...
Couldn't see any blue fluid in the tank for a couple of rides.
decided today to get the cap off and look inside with a view to a topup.
Pulled the tank back and took off the pressure cap and there was a white viscos foamy **** in there.
I will drain and flush tomorrow. Have taken out the drain plug fm water pump and all that comes out is pure blue anti f.
I know when I had a replacement Gearbox 700 miles ago the mechanic admitted that the said tank had slipped into some oil and taken some on. He had washed it thru a number of times and has offered at next service to flush the cooling system thru for free.
Oil level is fine and a good dark brown colour.
Coolant from the pump is blue and coolant like as expected.
Top header tank is full of milk.
Like I said will drain and flush tomorrow and refill.
Any advice welcome
Cheers guys
Nige
Old 04-Nov-2006, 21:20   #2
ducv2 ducv2 is offline
Had the same problem, found that the water pump seal had gone.
Old 05-Nov-2006, 21:08   #3
flushed through about 20 bucket fulls today and topped up the whole coolant system with the right stuff - took her for a blast and thrashed it ......and still have blue in the header,,time will tell ........will see what happens in the next couple of weeks
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:52.
