Old 28-Nov-2006, 07:47   #1
900SL Pete 900SL Pete is offline
900SL Pete's Avatar
Strip down
Can anyone help,
I am stripping the 748 to clean up and fettle over these dreary evenings, can you please tell me, if I take off the petrol tank there are three pipes underneath, if I disconnect them does petrol leak out?
There is about three quarts of a tank in there.
Thanks for your help
Old 28-Nov-2006, 08:24   #2
Monty's Avatar
In a word-yes. The 916/996 have quick release valves under there with seals but I assume your 748 doesn't?
John
Growing old-disgracefully!
Old 28-Nov-2006, 09:03   #3
Douglas Douglas is offline
I have had two 748s', which both had quick release valves on the tank, which automatically seal when you remove the pipe. I seem to remember that the later budget model (748E?) didnt have the quick release fittings.
Good luck with the winter fettle!
Douglas
Old 28-Nov-2006, 10:23   #4
900SL Pete's Avatar
It appears that the pipes just fit onto the tank connection elbow, I will give it a go
Pete
Old 28-Nov-2006, 20:20   #5
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Douglas
my 98 BP has quick release connectors. they still leak a little bit when disconnected, so even if your bike has 'em, have a rag ready underneath to catch the drips.
Old 28-Nov-2006, 21:33   #6
djb djb is offline
djb's Avatar
Surely if it has a pump it won't leak other than residual in the pipes?
No?
Okay, I'm going....
Old 29-Nov-2006, 10:54   #7
zhed44's Avatar
Mood: YELLOW!!!
No?
Okay, I'm going....
yes, that's what i meant - not a constant leak, but a little bit of residual fuel comes out when the pipes are pulled off. not very much, but enough to make it worthwhile having a rag to hand
Old 29-Nov-2006, 11:11   #8
Martinp Martinp is offline
Martinp's Avatar
Mood: 748ish
I'm just about to start this aswell will you need to replace the o-rings aswell?
Old 29-Nov-2006, 11:28   #9
If it's the E tank without the quick release connectors, either drain the tank or make up some blanking pipes. It will leak and continue to do so until it's emptied itself.
The o-rings on the QR connectors should be ok. Have a look for any nicks or cuts in them. Replace if in doubt. They are pennies anyhow. Use plenty of grease on reassembly.
Old 29-Nov-2006, 11:28   #10
keefer keefer is offline
keefer's Avatar
if they are the new green type then probably not
if they are the older black ones then I would exchange them for the newer
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:33.
