Old 11-Dec-2006, 21:30   #1
VanDaMauler VanDaMauler is offline
VanDaMauler's Avatar
Mood: www.zeitgeistmovie.com The Truth they dont want you to know.
996 rear wheel nut???
If you wanna nip down to halfords and get a socket to remove the wheel, what size is the nut?
TIA
VDM
Old 11-Dec-2006, 21:38   #2
46mm off the top of me head
Old 11-Dec-2006, 21:45   #3
rcgbob44's Avatar
You have a nut on the top of your head!
Things of beauty: Ducati 998s Mono: BSA DBD34: Vincent Black Shadow: Manx Norton: 1983 Laverda Jota: Matchles G50: Me!
Old 11-Dec-2006, 21:46   #4
doogalman's Avatar
Yup, 46mm. Normally they only have in stock the 1/2" impact version. No problem there. Best to grind the rounded bevel type edge off so you get the maximum grip. Best few quid you can spend. Don't forget the torque wrench or scaffold pole.
Old 11-Dec-2006, 22:01   #5
A 46mm one!
Old 11-Dec-2006, 22:05   #6
yeti yeti is offline
yeti's Avatar
46mm, and get your local machine shop to grind it down to the same height as the faces on the nut.
Old 11-Dec-2006, 22:14   #7
cheers chaps
Old 12-Dec-2006, 13:31   #8
spinoli1 spinoli1 is offline
Bikes: 998Bip
Mood: Carbonara
I strongly recommend getting a 3/4 inch drive socket and a 3/4 inch drive breaker bar. I broke/bent the following trying to remove mine:
2 x 1/2 in breaker bars, 2 (good) 1/2 in ratchets, 2 x 1/2 in tommy bars.
3/4 bar inch makes it easy.
Spin
Old 13-Dec-2006, 13:23   #9
gordonparker's Avatar
I would doubt if Halfords will stock this size, mine didn't.
Best to go to a local tool specialist
Old 13-Dec-2006, 13:55   #10
moto748 moto748 is offline
I bought one from Halfords, disguised as a 1 13/16" Ball Joint impact socket.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:09.
