Old 28-Apr-2004, 00:12   #1
fiirestorm fiirestorm is offline
916, 99*, 748 wheels on a multistrada ??
Is it possible to use 916 wheels on a multistrada ?
Can I keep the same front and rear calipers ?
Do I need spacers or different hubs etc for the front or rear ?
Do you forsee any other problems ?
[Edited on 27-4-2004 by fiirestorm]
Old 28-Apr-2004, 10:07   #2
So far what I have read is that the rear wheel fits fine, but the front needs a spacer to align the disc/rotor to the calipers.
My primary reason for asking is so that I can use normal disc carrier and floating disks in the attempt to get rid of the brake shudder.
Perhaps also if the wheel is lighter it will make a difference as the unsprung weight would be different.
My Ducati dealer seems impotent or unwilling to fix the problem - I'm getting fed up of it. :|
fiirestorm
Old 28-Apr-2004, 12:30   #3
superlight3 superlight3 is offline
superlight3's Avatar
Mood: Anything but 'Yellow-Bellied'..!
Yes, you can use the 916 series wheels on a Multistrada. But...
You'll need a new front axle tube, spacer and a new pair of 'standard' discs to replace the spoke-mounted ones fitted as OE.
All the parts are available off the shelf.
Cheers.
Lee.
http://www.monstershop-ducati.co.uk
Old 28-Apr-2004, 18:48   #4
Multi Rod Multi Rod is offline
I'm sure I read that the Multistrada wheels are lighter than the 999 wheels anyway.
I've had my Multi for nearly a year & 6500 miles, & I only felt the brake shudder once, & that was at about 2 mph while parking it. it's strange why some people suffer this & some don't.
Old 28-Apr-2004, 20:19   #5
I reckon I might have a spindle and spacer somewhere that I could sell?
Old 29-Apr-2004, 12:30   #6
Ian Ian is offline
Ian's Avatar
Mood: Still having fun!
yes, the above posts are correct, I was thinking of keeping my Marchesinis but when isaw the weight advantage against my the standard, I thought why bother? A spacer is needed for the front.
But in saying that....... the brake judder can be cured, Ducati have released another compound of brake pad, - by the look of it and the fact that some people get it and some don't it must be down to how the brakes are bedded in in the first place. I believe the general consensous is that it is best not to be too careful with the front brake, - and brake hard from time to time to stop the glaze.
Old 29-Apr-2004, 18:43   #7
Ian....
.....does this mean that you might sell me your mags?
Tim
Old 29-Apr-2004, 23:39   #8
Ian Ian is offline
Ian's Avatar
sorry Tim they went with the 916 in the end... They will be at the track day though, - Andy who bought the bike is going I think.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:02.
