Old 15-Oct-2025, 21:55   #1
3narf 3narf is offline
Bikes: KTM Duke 640
Which is the stronger engine?
Hi
I'm toying with the idea of building a lightweight air-cooled track day bike. I've had a 1991 750ss (Mikuni) and a 2000 900ss ie years ago, but which is the stronger engine between the 750 and the 900? There must be many years of accumulated knowledge by now.
I suppose logic dictates that the 750 is less stressed but is the bottom end different? I can't remember.
Anyway, let me know what you think!
A
Old 16-Oct-2025, 11:49   #2
Personally I doubt that there will be much between them in weight, if anything the 900SSie engine would probably be lighter given the modern updates it got over the 900 carb engine that was the basis for the 750.
If you compare weights of the whole bikes, the 1991 750SS was listed at 173kg dry weight compared to 188kg dry for the 2000 900SSie.
If you want to go really mad, get an 1100 engine from an early Hypermotard as they're 177kg dry weight but have 90hp and you can free a few more ponies and kg with the single can exhaust, probably double what a 750SS will put out
The IE models are also far less complicated to setup than a carby engine (again, IMHO!) with little difference again between a set of throttle bodies and a set of carbs.
In terms of strength... improvements in technology between a 1991 and a 2008 engine should be a no-brainer.
Old 16-Oct-2025, 14:52   #3
Bikes: KTM Duke 640
Many thanks!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:03.
