Old 27-Mar-2009, 14:30   #1
TopiToo TopiToo is offline
Bikes: 748ish . .
Mood: Sampai jumpa lagi
Steering stem bearings grease
Hello
just need to check, which grease is best to use on the above bearings?
any Lithium based such as Castrol LM Grease or would you advise
something else
TopiToo
Old 27-Mar-2009, 16:45   #2
Lightning Boy Lightning Boy is offline
Lightning Boy's Avatar
Mood: Waiting at the Crossroads......
Hi Steve,
Any Lithium Multi-Purpose based grease will do - although if you can find some (usually boat chandlers) there are some heavy duty greases for boating applications that have a very high tolerence against water and are good for steering head bearings. I remember alot of the MX boys used it as they were constantly jet-washing their bikes - they used it for wheel bearings too.
LB
Old 27-Mar-2009, 16:57   #3
YMFB YMFB is offline
YMFB's Avatar
what about the ACF 50 Grease ?
Old 27-Mar-2009, 17:56   #4
Bikes: 748ish . .
Originally Posted by Lightning Boy
Hi Steve,
LB
Hello Lightning Boy
Thanks for that, I have a mate who works in a dry dock local to me
If I am out and about tomorrow will ask him, I guessed the standard grease would be ok, the bottom bearing/racer seems to be worse for wear,
(i guess due to being close to the wheel and water)
The top bearing looks fine, but will change both sets over with some new tapered bearings/seals which arrived today
TopiToo
Old 27-Mar-2009, 17:59   #5
Bikes: 748ish . .
Hello YMFB
thankyou for that, will have a look online.
TopiToo
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:29.
