Old 09-May-2009, 20:15   #1
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Angry Chemical Metal, Glue, Solder or Braze?
I've managed to shear the -ve terminal off the battery when fitting an Optimate flylead this afternoon.
I don't intend to fork out £70 or whatever it is for a new battery, so I want to try to fix it. Long story short - I can get a good contact by wedging the end of the sheared off bit of the terminal between the battery body and the stub of the terminal. However, I need to secure it somehow.
What's the easiest/best way to do it?
My favourites at the moment are to either use chemical metal or melt some lead over and around the joint.
Any thoughts?
Old 09-May-2009, 20:47   #2
mjbayley mjbayley is offline
mjbayley's Avatar
Mood: Been Testing the 3 P's (Pizza, Pasta, & PERONI!)
New Battery the only answer!
You will go round and round trying to fix broken lead to lead, none of it will work and it will let you down when you most need it !!
Sorry to be a doom monger, but have been there done that.........
Old 09-May-2009, 21:06   #3
steve byatt steve byatt is offline
Bikes: 800s shells monster
steve byatt's Avatar
Mood: get naked
Any thoughts?
new battery any repair wont last sorry
Old 09-May-2009, 21:14   #4
zhed44's Avatar
Mood: YELLOW!!!
It's not lead to lead. The terminal is made of brass or something similar (see pic: http://shop.wemoto.com/pictures/full...Y/10001745.jpg)
It's difficult to describe because I've reshaped the metal of the terminal, but I can get a good tight contact by wedging a flat bit of the terminal between the stub and the body of battery. I then just need to encase the join in something solid so it can't vibrate loose.
Old 09-May-2009, 21:24   #5
Mood: get naked
just payed £45 for the same battery moto rapio good luck with the repair
Old 09-May-2009, 21:33   #6
zhed44's Avatar
Mood: YELLOW!!!
Thanks. That's not bad. If I can get one for round about that sort of money, I may just repair my battery as a temporary measure until the new one arrives.
Old 09-May-2009, 23:17   #7
YMFB YMFB is offline
YMFB's Avatar
any repair will almost certainly be temporary so get the new one ordered.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 03:12.
