Old 04-Jun-2004, 22:22   #1
mogwai mogwai is offline
mogwai's Avatar
Mood: IF IN DOUBT..GET BLAGGING.
Clutch and front brake levers..........
Whats the crack with moving them down ?,recall a thread about having to snap some locating pins to do it or something like that.......?,any advice shadies and mentalmen ?.Cheers,moggers@****erscramp.com
Old 04-Jun-2004, 23:55   #2
Nelly pulled mine out with a set of pliers - and then they are done. It is a lot more comfortable now - just need a front tyre that isn't scalloped to comeplete the transformation and I'll be very happy ... Spent an hour putting on new carbon bits today Woohoo!!
As weeksy says, split the swtich blocks and you'll see the pin there. You can either pull them out with pliers or cut them off, personally I prefer the cut them off approach ...
Old 05-Jun-2004, 00:38   #3
Mr_S Mr_S is offline
pulled mine with a set of mole grips in about 5 seconds flat, so if the mood should take me I can replace them (with the appropriate tools of course)
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 06:06.
