Old 17-Jul-2009, 20:31   #1
rapidomoto rapidomoto is offline
749R Ohlins for a 2000 748s
On just a purely cosmetic front, can the Ohlins forks which are spec'd on the 749R with the solid radial brake mount fit straight onto a 748s? Would the forks fit in the std 748 fork clamps? Additional I would need new calipers but would i still be able to use the std diameter discs or are the 749R discs larger?
I find the std brake setup perfectly adequate, but having dirty thoughts on how good this setup would look on my 748!....
Old 17-Jul-2009, 20:57   #2
I think that I have been told in the past that they are shorter than the 748 ones.
Old 18-Jul-2009, 00:07   #3
powerwheelie powerwheelie is offline
They do fit, you need the triple clamps (53mm top - same as Showa and 56 bottom). If they´re shorter, just mount them lower to get the proper ride height. Shouldn´t be a problem.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:11.
