Old 27-Jun-2011, 22:51   #1
Front Disc
Anyone got a front disc that they wish to part with. I have to balast my lightweight.........ish bike up a couple of Kg, so a caliper and disc will be just on the mark of minimum weight.
I have the caliper just the disc I require.
Old 27-Jun-2011, 23:25   #2
given rotational mass, unsprung weight blah blah blah wouldnt you be better adding ballast low in the centre? Heavy belly pan, something like that?
Old 27-Jun-2011, 23:49   #3
You are learning aren't you
Phil was there a specific type/pattern you were after
Old 28-Jun-2011, 06:43   #4
Kev the one I have on at present is from a (TZ 250). But anything would do its a race bike so I'm not after aesthetics.
Ironic thing is I gave one to my brother to put on a 600ss to convert to twin discs on a bike he was selling last month.
That small amount of mass Paul will make 3/5th's of f@<>all difference and just provide a little bit more Woah for Pembrey hairpin.
Old 28-Jun-2011, 07:16   #5
disc and caliper was 5kgs on mine Phil...hence I only have the 1
Old 28-Jun-2011, 08:41   #6
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Think I have one lying around you can have Phil.
Old 28-Jun-2011, 10:12   #7
Thanks Chaz I'll pm you later to sort the logistics. Paul my bike was 152.5 at snett, so it will work out just right for me.
Old 28-Jun-2011, 10:54   #8
cor blimey!! Mines about 170 !! Can I drop mine at your place so you can work some magic?!
Old 28-Jun-2011, 12:03   #9
Cranker V2's Avatar
Mood: Green with envy
Phil; if you need a disc I have a solocorse one spare ( its a bit warped). You could run it with no caliper and achieve the required weight then.
Old 28-Jun-2011, 15:19   #10
Cheers Mike, at snet I used a caliper and no disc and a spare chain under the seat. But I'll take Chaz up on his offer.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:56.
