Old 18-Nov-2011, 16:29   #1
fiel cell foam
anyone used it?
http://www.eti-fuelcel.com/1098.html
Old 18-Nov-2011, 16:36   #2
Originally Posted by bradders
Used fuel cell foam before, its just open cell foam prevents sloshing of the liquid.
Old 18-Nov-2011, 16:46   #3
make a difference? thinking 9l sloshing about a 17l tank it may be worthwhile, not sure how much weight it adds
Old 18-Nov-2011, 17:52   #4
Doesn't add much weight, I have a decent sized lump of it in the garage.
I doubt if Dallas has had a race bike where he hasn't fitted the baffle foam, I think but would need to check that its a requirement at BSB level and above
Old 18-Nov-2011, 17:58   #5
Jolley Jolley is offline
Bikes: 959
Jolley's Avatar
I'm pretty sure they have to use it in 848 challenge too.
Old 18-Nov-2011, 18:02   #6
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
Yes they do infact any BSB level have to use it.
Old 18-Nov-2011, 18:07   #7
Glad you knew what I meant Chaz, hence the wording 'BSB Level' and not 'BSB Class'
Old 18-Nov-2011, 18:10   #8
so its a good thing then
lots of small blocks or one big one? How much?
Old 18-Nov-2011, 18:14   #9
You will end up cutting it into blocks to get it into the tank, what size blocks depends on the tank and its entry points
Old 18-Nov-2011, 19:02   #10
so do you fill the tank, half fill it, 1/4?
my simple mind wonder how the fuel gets out again!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:56.
