Old 26-Dec-2011, 08:28   #1
dunlop0_1's Avatar
Air filter Options
In the new year I am going to be getting the 996 power commander checked out and the bike dyno'd.
It currently has oe air filters and wanted to know what recommendations people have or tried?
DP chip to match SPS system with carbon Termi's (not the longer cans which interfere with the seat unit).
Cheers.
Neil
Old 26-Dec-2011, 09:29   #2
The Piper-X ones work well, £19 off Ebay when I last looked
They replace the original foam in the original holders, trouble is not all Carbon Intake tubes can hold them, but as you currently have OE filters your not going to have that problem
http://www.ebay.co.uk/itm/Ducati-Pip...em5d29c 09563
Old 26-Dec-2011, 13:23   #3
dunlop0_1's Avatar
Cheers Kev.
Seen those and the all in one foam type but was unsure of the difference, if any.
Gonna order them right now.
Old 26-Dec-2011, 14:37   #4
Neil any filter sitting over the intakes should result in a reduction (no matter how small) in performance as the Airbox is designed as a resonant chamber, which is why sticking them in the air-tubes is a good idea
Te Piper-X ones have a two stage filter and come well oiled. I run them in the Carbon air ducts on my 998R
Old 26-Dec-2011, 15:52   #5
Chaz Chaz is offline
Bikes: 916 Strada
Chaz's Avatar
Mood: www.od2racing.co.uk
I use the bmc ones bit pricey though.
Old 26-Dec-2011, 16:38   #6
Pricy as Chaz said, but handy if you are using carbon fibre air tubes.
http://www.moorespeedracing.co.uk/du...ir-filter.html
Old 27-Dec-2011, 10:05   #7
Ray Ray is offline
Ray's Avatar
Have you ditched the wire mesh on the air intakes? They are a big restriction on how much air those twin cylinders can gulp in.
It will make the bike run a little lean but you can fix that with the powercommander.
Ray.
Old 27-Dec-2011, 15:58   #8
Cranker V2's Avatar
Mood: Green with envy
carbon tubes , mesh over intakes and no filters on my track 853r. Obvioulsly running risk of gulping in lumps of whatever. I would run the pipercross filters with standard airtubes.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:48.
