Old 05-Mar-2012, 15:36   #1
ChrisBushell's Avatar
Mood: Im Going to Italy soon!
Belts on a 998S
Guys inspired by AntonyE's article about changing belts, I have downloaded the checking software, got a microphone working off the lap top and thought I would have a go at checking the current tension on the bike - before moving up to actualy changing and tensioning them.
The one bit of information that I am missing though is what sort of frequency should we be looking for?
Old 05-Mar-2012, 15:54   #2
chrisw chrisw is offline
Bikes: 999 Mono/1198S
chrisw's Avatar
110 Hz (+/- 5Hz)
Old 05-Mar-2012, 17:44   #3
Originally Posted by chrisw
110 Hz (+/- 5Hz)
Thank you for that -will try on Saturday!
Old 05-Mar-2012, 18:12   #4
khu996 khu996 is offline
khu996's Avatar
110 Hz (+/- 5Hz)
Isn't that for new belts??
I might be wrong, but I think used belts are around 80Hz.
Old 05-Mar-2012, 18:26   #5
your thinking of the minimum allowed, anything around 70 to 80 Hz is apparently acceptable, anything less and they NEED to be retensioned
Normal operational tension is 110/110 (± 5) so thats what should be set new or used
Old 05-Mar-2012, 18:33   #6
A Ducati bulletin specifies that recommended tension for installing fresh out of the box new belts and the acceptable range of deviation (110 Hz +/-5Hz). It also states that if you are going to reinstall a set of used belts they should be adjusted to 90-100 Hz (+/- 5Hz). It further implies that used belts can be left alone if they measure above 70Hz.
What Ducati is saying is to first set the tension of a new belt to spec, expect them to lose a slight amount of tension after some initial miles, and then verify at any later time that this tension is above the minimum requirement. In other words, you should not re-adjust the tension to the new belt spec max after run-in.
Otherwise the belt will be in danger of snapping after a few re-tensionings.
Old 05-Mar-2012, 19:06   #7
chrisw's Avatar
Thanks. Created a crib sheet with the info to put with all my manuals.
Old 05-Mar-2012, 20:10   #8
Manga Manga is offline
Bikes: Ducati 996B, Triumph Sprint ST 955i
Any chance you can put a link to the original post?
Something else to stress myself about I suppose.
When I bought the bike, the workshop told me the belts wont need retensioning, just changing every 2 years or so.
Old 05-Mar-2012, 20:26   #9
Cobbett Cobbett is offline
Bikes: 750ss, 998s
Cobbett's Avatar
2 years is indeed the change interval (or 12k miles, whichever is sooner). But the tension should be checked and adjusted if necessary at the intervening annual service.
Old 05-Mar-2012, 22:25   #10
This is what I use Chris, it came from Gates Spring last year so about a year after the Bulletin from Ducati North America, I often wonder if they are just trying to protect themselves from idiots. As that Bulletin says all Ducati belts are now tensioned to 110/110 (± 5) be they 4-Valve or 2-Valve and no difference between front and back belts on any of the aircooleds
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 16:07.
