Old 19-Jul-2006, 14:18   #1
Col996s Col996s is offline
Bikes: 996S
Col996s's Avatar
Temp gauge light
I don't normally ride much after dark but when I did the other evening I noticed that the temp. gauge did not light up. I assume it should and I have a blown bulb?
Old 19-Jul-2006, 14:51   #2
Most probably. You'll need to get the top fairing off to get at it though, and that means removing:
side panels
mirrors
top panel
headlight
once you've done that, you'll be able to (just!) get access to the three nuts that hold the clocks in place. Undo those and the clocks will lift out so you can replace the bulb.
Now you know why it hasn't been changed before...
Old 19-Jul-2006, 15:30   #3
Bikes: 996S
Col996s's Avatar
User friendly then.
Old 19-Jul-2006, 15:56   #4
Agree with Antonye except to add that if you're lucky (I wasn't) you won't have dislodged any electrical connections and won't have to undo it all again.... Oh, and I found it easier to disconnect the speedo drive as well. I did the job once and decided that if it blew again, it could stay blown! Masterpiece of design...
Andrew
Old 19-Jul-2006, 16:03   #5
It gets easier the more you do it, but yes it is a pain!
If you want to pop over to mine I'll give you a hand with it Colin?
Old 19-Jul-2006, 20:23   #6
Bikes: 996S
Col996s's Avatar
Thanks Ant. I'll get a replacement one first. Is it a special or can I get one from Halfords?
Old 19-Jul-2006, 22:37   #7
Dunno, tbh.
Could check the Haynes Book of Lies but I can't see straight right now.
I'll try again in the morning when I'm not too drunkered.
Old 21-Jul-2006, 01:31   #8
Paul748bp Paul748bp is offline
Paul748bp's Avatar
simple solution !
ride the bike in the day my bulb has gone and even my dealer said dont bother with it to much effort
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 20:36.
