Old 19-Apr-2005, 16:45   #9
neil748r neil748r is offline
Another plus point about the Renthal carrier is that it uses replaceable studs to secure sprocket which are long enough to use a nyloc nut.
All the other carriers I've seen are drilled and tapped so you have the potential problem of sprockets comming loose (not unknown) and if you happen to strip one of the threads it's new carrier time.
Renthal every time!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:49.
