Old 05-May-2005, 20:21   #2
yeti yeti is offline
yeti's Avatar
For starters, don't even think about fitting it "dry" if you have never done this before. Peel the backing paper off first, then believe it or not drop the sticker into a bucket of warm water with no more than a couple of drops of fairy liquid or the like. When you lift it out you will be able to apply it easily and even shift it about if not in exactly the right place. Then use a palstic squegee to squidge the remainin liquid out.
With regard to the front, you may just have to trim it off carefully with a craft knife.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 12:55.
