Old 20-Jul-2005, 10:26   #1
m1keyp m1keyp is offline
A REAR BRAKE ANSWER???
Just reading in motorcycle news that Aprilia say that using DOT5 fluid in their rear brakes sorts the going soft problem.
Does it work on a Ducati?
Has anyone tried it?
Cheers Mike
Old 20-Jul-2005, 11:20   #2
I already use DOT5 and it still goes soft...
I think it's a general design fault in the way that the rear caliper is mounted in relation to the master cylinder and the run of the hose.
The SS has one really demon sharp rear brake and has never required bleeding, yet it uses the same system components. The difference is that the master cylinder is mounted vertically and not horizontally, and the caliper is mounted above the line of the m/c as it sits above the rear axle and not below.
I know the monsters use this configuration too, and also the 999/749 have gone back to mounting the rear caliper above the rear axle, but retain the horizontal master cylinder - do these suffer the same? If not, I'd be tempted to deduce it's just the location of the caliper.
Old 20-Jul-2005, 12:21   #3
Mood: me in a mood? NEVER!
I run DOT 6 and it isnt that bad. they stock it in the demon tweeks catalogue
Old 20-Jul-2005, 12:25   #4
les996 les996 is offline
les996's Avatar
Mood: :-0
never use the back brake...
...but then only go out on dry roads.
Old 20-Jul-2005, 12:27   #5
Or get your bike MOT'ed I presume?
Old 20-Jul-2005, 12:34   #6
Its approaching MOT time!!!!!
The only time it will ever get used
Old 20-Jul-2005, 13:01   #7
MarkyMark76 MarkyMark76 is offline
Mood: .
Mine got MOT'd at the weekend. Not so easy to sneak under the radar now with the new computer methodology.
My major worry was the back brake as it really is useless, but it did stop the rollers eventually with a good stamp and when the numbers were fed in to the computer it said PASS ! ! ! ! Mightily relieved!
Old 20-Jul-2005, 13:17   #8
748IOM 748IOM is offline
Mood: Yellow!!
Luckily don't have the MOT worry here on the Isle of Man
Old 20-Jul-2005, 13:45   #9
Has anyone used a mityvac? I did a search and there appears confusion over the instructions/units efficiency
Old 20-Jul-2005, 14:03   #10
rcgbob44's Avatar
Fit a 4 pston caliper to make it work at all.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 10:14.
