Alarms and Related Security
Old 04-Oct-2005, 13:03   #1
blueduke blueduke is offline
blueduke's Avatar
Mood: Monster Mania?
sold secure my ar*e
Oops!
http://www.zanx.net/soldsecuremyarse.wmv
Old 04-Oct-2005, 13:42   #2
Jasper Jasper is offline
Jasper's Avatar
Is tha the ones they wouldn't withraw-until all the shops refused to stock them?
Old 04-Oct-2005, 13:43   #3
My favourite party trick - opening a barrel lock with a pen!
This is about a year old and most manufacturers withdrew stock and offered free replacements.
Handy to know though - I certainly don't use one anymore.
Old 04-Oct-2005, 13:48   #4
HW HW is offline
wow .... I knew about this but that's the first time I've seen it done. I always assumed it was the pointy end of a pen you had to prod about with, not just a bit of plastic tube shoved in the lock!
Old 04-Oct-2005, 16:00   #5
YMFB YMFB is offline
YMFB's Avatar
my ST4 came supplied with a U lock under the seat, the key/lock part looks remarkably similar to the one in the video.
Anyone know if the same trick works on the Ducati supplied locks as I dont appear to have a pen that is the correct colour sorry diameter to test it.
Old 04-Oct-2005, 16:24   #6
It does work on all barrel locks (allegedly) if you have the right diameter and softness of pen. The plastic deforms as you push it into the barrel and with a twist of the wrist the pins find their own keying, to allow the lock to open.
Beware that it f**ks your lock up as I've not been able to reset the lock using the same method, without filing down the tab on the key and doing it that way!
I find that my daughter's Crayola Colouring felt-tip lids are the best ones, but once the plastic starts to wear you need to trim it down with a knife or pair of scissors to make it work again.
I'll try to remember to bring my demo lock and pens along to Cadwell and will teach you how to do it...
Old 04-Oct-2005, 16:49   #7
BIG-G BIG-G is offline
BIG-G's Avatar
Mood: I started life with nothing and still have most of it left
I'm still using one of these. They should sell the added feature that if you loose your keys you only need a pen.
G
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 18:46.
