Old 29-Oct-2005, 16:16   #11
748mart 748mart is offline
Originally posted by ericthered40
All as above BUT!!!!! before you do anything undo the swing arm pivot bolt and remove the shaft grease it and slide it back in. It may be seized and take some getting out, it's much easier with the whole bike together.
The pained expression on the mans face who gave me that advice made me take notice.
The swing arm is captive in the frame witch needs springing open before you can remove it so you can draw the bolt with the wheel and suspension in Place.
I plan to do the same this winter, in fact I've already started.
[Edited on 29-10-2005 by ericthered40]
The Biggest advantage of working on the swinging arm bolt before stripping bike is it helps if you run the bike upto temperature when attempting draw the b***er out.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:40.
