Old 01-Apr-2006, 18:20   #1
i porter i porter is offline
Brembo pad removal.
Hello again thicko here. Can someone explain how to remove the 4 pads from the brembo front calliper.
I see the clip and a pin that goes through. Is it just the case of removing the pin and the clip then the pads will come out.
Or have I to do something else. Thankyou.
Old 01-Apr-2006, 18:55   #2
Mood: Come on spring!!!
pads
Push the wire clip in and pull the pin that slide thru from the side out! Might need pliers to pull it out!
Old 01-Apr-2006, 19:03   #3
Thanks Chris Ill have a go.
Old 02-Apr-2006, 11:41   #4
Bikes: 748R, ZXR 400
raykay748R's Avatar
Don't forget a wiggle side to side to push piston back a little in order to pull out the pad, by that I mean the pad wiggles, not you!!!!!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:22.
