Old 14-May-2006, 14:17   #6
zhed44 zhed44 is offline
zhed44's Avatar
Mood: YELLOW!!!
Originally posted by KeefyB
How much of the bolt is sticking out of the spring post?Is there enough metal there to get some molegrips on it?
none whatsoever. it's snapped approx 4 or 5mm into the hole, otherwise i would have been onto it with the mole grips or would have cut a slot for a screw driver straight away.
i also don't think it's going to be too easy to get at with a centrepunch either due to the depth and the narrowness of the hole and so if stude extractors are to be used, it may need drilling without a starting point - and the broken surface is very rough, so that's going to be a bit precarious!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:45.
