Old 09-Nov-2006, 13:16   #1
DSC Member MJS MJS is offline
Bikes: None at the moment
MJS's Avatar
Mood: Feeling old...
Help - renaming files
Guys
As a useful source of information on all things.... I thought I'd try asking this here...
We have to rename a whole bunch of files - somewhere in the region of 7500 to be precise. But, we need to retain the original name and append a revision number to them, so AB12345.xyz would become AB12345rev1.xyz
Is there an easy way of doing this? Any useful little power tool that can be downloaded and used for it?
Thanks for any advice - don't want to have to get someone to go through and rename them all manually
Martin
Old 09-Nov-2006, 13:21   #2
Red-Duc Red-Duc is offline
Red-Duc's Avatar
Dont know much about this really but Can you not just save a copy of the files into another folder and call it revisions,
Old 09-Nov-2006, 13:27   #3
MJS's Avatar
No, it's to send to a sub-contractor, and with several thousand files floating about, they will inevitably get mixed up... and contractually we're obliged to name the files as such...
Old 09-Nov-2006, 13:33   #4
Red-Duc's Avatar
well I hope someone can come up with an answer for you, I wouldnt fancy that job of renaming them all individually
Old 09-Nov-2006, 13:34   #5
Save this as "rename.vbs" in the target directory.
Edit it so that the sPath is the name of the folder, and the sExt
is the name of the extension you wish to check (to filter for
just .gif files, for example).
Double click it in Windows Explorer and it should do the trick.
-- 8< -- cut here -- 8< --
sPath = "c:\temp\folder\"
sExt = ".gif"
Set fsoObject = CreateObject("Scripting.FileSystemObject")
Set fsoFolder = fsoObject.GetFolder(sPath)
for each fsoFile in fsoFolder.Files
if (Right(fsoFile.Name, Len(sExt)) = sExt) then
sNewName = Replace(fsoFile.Name, ".", "_rev1.")
fsoFile.Name = LCase(sNewName)
end if
next
Set fsoFolder = Nothing
Set fsoObject = Nothing
Old 09-Nov-2006, 13:39   #6
Gizmo Gizmo is offline
Mood: is it the weekend yet??
if you can't find a windoze program copy the files onto a mac and run the automater action "rename finder items", select "add text", "after name" add rev1 and it'll batch rename them for you, you can create a copy if you don't want to rename the original files.
Old 09-Nov-2006, 13:41   #7
phil_h phil_h is offline
phil_h's Avatar
Nice idea antony.
Be brave martin, he's teaching you how to use script files
BUT !!!
test it out on something simple first
Old 09-Nov-2006, 13:50   #8
MJS's Avatar
sExt = ".gif"
end if
next
Cheers for that.... as Phil says, I'll try it on something simple first.....!
Martin
Old 09-Nov-2006, 13:52   #9
Heh, obviously!
PS. Where do I send the bill?
Old 09-Nov-2006, 13:56   #10
MJS's Avatar
Heh, obviously!
Poland... You take Zloty?
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 00:11.
