Old 14-Dec-2006, 01:31   #8
testastretta testastretta is offline
testastretta's Avatar
Unless you have a wiring diagram, there's not a lot you are going to be able to do - assuming a wiring diagram was available, which gave test points and the expected voltages at each, you could (depending on your abilities etc) possibly identify if this was just a faulty component like a resistor etc, but without a wiring diag, you really are shooting in the dark. - and I agree with previous posts, there is absolutely no way a DVD unit should be running anything higher than a 5amp fuse. You might want to check your other similar appliances for over-weight fuses, unless they have smaller internal fuses to blow sooner, 13 amp fuses are not protecting your kit from damage !
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:10.
