Old 11-Jan-2004, 14:58   #1
wildcard0023 wildcard0023 is offline
bike won\"t start
Bikes been stored for 3 months or so on a optimate.Started up first time & ran for about 10 secs & stalled,will turnover but not fire.Took out top plug,bit black but dry.
I don"t no whether this is connected to a prob i was having last summer,it would want to cut out a high revs e.g. overtaking a car or at high speeds,it feels like you"ve hit the rev limiter.The bikes a 853r any help would be appreciated.
Old 11-Jan-2004, 15:51   #2
Mark853 Mark853 is offline
Mood: The medication helps!
Don't wish to offend you in any way but you havent nun out of fuel have you?
Done it myself!!!!!!!!!!!!!
Sounds like fuel is the fuel pump making all the right noises?
Sorry cant be more helpfull but dificult to sort on line.
Mark
Old 11-Jan-2004, 16:05   #3
That"s what i thought as the reserve light was on,so i drained what was in the tank & filled with fresh petrol,you can see & smell petrol squirting onto top of butterflies you can also hear pump priming.
Thanks for reply
Old 11-Jan-2004, 16:29   #4
Don't know then mate, try ringing JHP and speak to Jeff he's a good bloke, 02476335300, he may be able to help.
Hope you sort it
Mark
Old 11-Jan-2004, 18:45   #5
Jasper Jasper is offline
Jasper's Avatar
WEEKSY!!Just when you were showing some mechanical ability!Since when did fuel injected bike have carbs?:P
Old 11-Jan-2004, 21:06   #6
Weeksy,851's are injected too!
Go and stand in the corner!
Ok,where were we?Oh yes bike not starting,......er dodgy kill switch?Can get corroded if it comes into contact with a lot of water.
Or dodgy engine management relay?
Old 12-Jan-2004, 03:53   #7
Marty916 Marty916 is offline
Check that your fuel lines inside the tank aren't split. A common problem with the later 4 valvers, not sure about the 851....
Old 12-Jan-2004, 10:43   #8
... or that you haven't kinked the hoses last time you took the tank off...!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 13:31.
