Old 25-Jul-2009, 00:47   #2
andy.fletcher andy.fletcher is offline
For Sale
FOR SALE £3000
Ducati 748 ( 853 Big Bore )
Here is my 748 bp which has recently been rebuilt with an 853 big bore kit. The bike runs and rides great and wants for nothing. I have replaced or upgraded many parts as follows.
Full Spec
853 big bore kit with High compression dome pistons
50mm T/bodies and 748 sps cams
Magnecor HT leads and Platinum NGK plugs
Pvm ( same as magura 190 ) Radial master cylinder
Braided brake hoses
New performance friction brake pads
New Blue Airmax coolant hoses
Ducati performance rearsets ( race shift pattern )
Renthal Quick release sprocket carrier
520 gold chain 15/ 41 gearing
Pipercross air filters
45mm Carbon termignoni exhausts + originals
Power commander III and custom fuel map ( YPE perf )
Rear shock has racetech internals
5.75" PVM magnesium rear wheel
Pirelli diablo rosso`s with lots of life left
Ducati 3 ramp slipper clutch
New alloy clutch basket
Vented Clutch housing
Race fuel Cap
wavy rear brake disc
Later style flat sided fairing panels with full belly pan
Carbon , front fender , airtube covers, airbox side panels with dzus fasteners, hugger , swingarm guard, Exhaust guard, clutch cover
Taxed and Mot`d
As part of the rebuild i replaced many parts
New battery
New coolant header tank
New rectifier
Re-wired generator with thicker gauge wire
New oil cooler + earl oil lines
New Front wheel bearings
Fork oil changed
Cam belts and valve clearances done 500 miles ago
Just changed Plugs oil and filter , Motul 300v 15w-50
All fluids changed
Calipers serviced
Also included in the sale
The only bad points is there are a few small marks on the frame and rear wheel, But overall the bike is very clean. The engine and cases have been re-painted. I have probably forgotten something because i`ve done so much to it over the past year so i may add more if i remember.
tel 07834159134 or email afefjf@aol.com
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:13.
