Old 10-Nov-2009, 19:28   #28
Monty's Avatar
Originally Posted by John W
from: http://www.onewheeldrive.net/2009/11...200-in-detail/
"The gearbox and final drive ratios have also been optimised to enable the use of a higher-ratio 6th gear. This solution not only enables reduced fuel consumption, but also achieves increased riding comfort by reducing vibration. To give a practical example, if the 1198 reaches its top speed in 6th gear, the Multistrada 1200 is able to reach it in 5th gear and maintain it effortlessly in 6th."
Given just how highly the Dukes are normally geared, this sounds like 6th will be next to useless, and 5th might be too...
I have worked out the gearing charts-I know, I know, I'm a sad case-anyway the gears are all the same as existing Monster/Multistrada/ST4S with the exception of 6th-which is higher than the Monster/Multistrada, and lower than the ST4S. Since I have been informed-indirectly-by Domenicali himself that the engine with it's new tune will pull happily from 2000rpm in 6th-'like an electric motor' I don't think we have much to worry about. The gearing works out that the bike will do 154 at peak power in 6th and 167 at 10,000 rpm. Personally I don't have any doubt that with 150bhp available it will manage to hit at least 154-if not more.
I have attached the chart if anyone is interested.
John
Growing old-disgracefully!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 01:13.
