Old 23-Nov-2009, 22:15   #13
A good tip for removing pins is to get a plastic or metal tube that will just slide over the pin. Push this over the pin to remove and it will close the tabs in and you can remove it from the other side. A little bit of jiggling on the wire helps too!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 04:14.
