Old 11-Feb-2012, 19:05   #1
900MAN 900MAN is offline
900MAN's Avatar
Mood: 900 went 999 gone, Multi came and went, 749 Nero now
A call to my Essex friends
Anybody smart enough to remove a ******* Allen screw that has stripped.
It had to be the one nearest and close under the hinge of the fuel filler cap.(749)
Tried whacking anti clock with a flat blade, tried to grind so I could use a flat blade driver but Can't grind propertly because of sparks etc.
Can only a see a quick spot weld of a tool onto it but who wants welding type stuff near the fuel tank opening
Old 11-Feb-2012, 19:43   #2
tcat tcat is offline
Bikes: Ducati 748r-853r / SF 1098s
tcat's Avatar
Mood: ...much happier.
If it was me, I'd use a dremel with a very small drill bit - drill through the centre (v. Slowly) and it should then collapse in on itself... suck out the rubbish with a hoover. Works a treat!!!
Old 12-Feb-2012, 00:00   #3
900MAN's Avatar
Did think that but because it's the screw close to the hinge section there is no room
Old 12-Feb-2012, 00:05   #4
Take a picture as it might help with ideas?
Old 12-Feb-2012, 00:36   #5
peter grover peter grover is offline
what i have done in the past, if you have room, is to gently hammer a torque bit into the head of the allen screw it has worked for me ok.good luck.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:34.
