Old 21-Aug-2012, 16:27   #4
Originally Posted by ChrisBushell
My 2002 998 uses an H1 and an H3 from memory.
Don't forget that the 916 used a different headlight configuration to the 996/998 as the charging circuit couldn't handle both dipped and full beam being on at once! There may also be a difference in the bulbs, so worth checking what it should be in the manual as it could already be wrong, or that using the same bulb as a 998 is wrong!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 23:14.
