Old 08-Sep-2004, 15:24   #5
748mart 748mart is offline
Don't forget you will need to unbolt the front calipers to remove the wheel, I think they are 8mm (or maybe 10mm) allen type & best to use socket type instead of key so you can torque correctly.
Be carefull when tightening front wheel nut as Antonye discovered this will split in half if overtightened.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 08:40.
