Old 23-Feb-2005, 15:32   #11
Lee1980 Lee1980 is offline
Bikes: Xdaivel
Lee1980's Avatar
Mood: Xdiavel..awesome!!
Yep i fitted them over the standard mid section instead of inside, where the 45mm's went.
I haven't measured them but assume the 45mm open ones would go on the inside as standard, and mine are 50mm so just fit over the outside is a tight fit though, I bought them of a member so trust they 50mm.
No leaks or anything works fine
Old 23-Feb-2005, 15:37   #12
ziggi ziggi is offline
ziggi's Avatar
Just getting back on topic for a mo .....
I'm thinking that a range of chips that club members could try out - maybe a library of chips that could be circulated to try the best one and then, of course purchase the said chip to fit your bike might be a good idea. ( i can always dream) - can you copy Ultimap chips? - for backup purposes only you understand - and in the interest of perfect running Ducatis .
Old 23-Feb-2005, 15:46   #13
Try measuring both sets - would be good to know!
Old 23-Feb-2005, 15:49   #14
Bikes: Xdaivel
Lee1980's Avatar
Wheres best to measure? can i measure the tail pipe? inner or outer diameter?
Or the outside of a link pipe?
Old 23-Feb-2005, 15:53   #15
internal diameters of the pipes themselves - measure both ends (end can and connector side) of the cans and then both ends of the link pipe.
Old 23-Feb-2005, 18:06   #16
Mr_S Mr_S is offline
You can copy anything with the right tools, but....
The thing with the Ultimap is getting it setup in the first place, so although you could copy the EEPROM, you'd still need to get it set up.
Old 23-Feb-2005, 18:31   #17
tony h tony h is offline
probably got it round my neck but when nelly set up my 996 with single injector ultimap eprom i asked about fuel mixture i,e rich/lean . Yes an eprom swap will alter perameters including fuel but you can still ajust mixture yourself using a base setting .just because you put an eprom on to match a 45/50 termi it dont always mean your mixtures right .so you should still av it set up
Old 27-Feb-2005, 16:55   #18
Bikes: Xdaivel
Lee1980's Avatar
Hi antonye,
measured them 50mm and heres a pic showing the 50mm over the 45mm
Old 27-Feb-2005, 16:57   #19
Bikes: Xdaivel
Lee1980's Avatar
and heres a bit of bling i got from Nattyboy
Old 27-Feb-2005, 18:37   #20
Mike Davis Mike Davis is offline
Mood: Shiney
The problem with the way you have done it Lee1980 is you might aswell have only fitted 45mm`s.
The reason for the link piece in 50mm`s is that the standard link pipe contains baffling that restrict the flow, removing this allows more power to be released from the engine.
On the subject of chips, a lot of aftermarket exhaust companies supply systems that will run on a standard bike without chip modification and without detramental damage to the motor
The reason for the chip is this helps release more power from the engine by altering the fuel mapping slightly, a cheaper option to a Powercommander.
Ducati`s run better with a 4-6% CO.
A lot of problems with rough running occur when dealers fit cans, chips etc but do not set the fuelling up correctly on idle.
This is not restricted to Ducati`s we have many bikes with Powercommander and Dynojet kits that run rough because the carbs and injectors have`nt been balanced, it is the same for Ducati`s, just putting cans on or replacing the chip is not really enough, the fuelling needs to be set up to the right CO and within 0.5% between the cylinders.
Hope this helps dispel any fears about not fitting chips with 45mm sytems.
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:59.
