Old 21-Mar-2005, 12:42   #11
fil2 fil2 is offline
fil2's Avatar
Mood: is it still wet
i best get a different disc then or im gonna loose out i guess.......
Phil
Old 21-Mar-2005, 12:49   #12
I remember weighing my 916BP disc (same as 600SS) my 748RS disc and a SPS disc and found there was very little difference in weight. My wavey discs are no lighter either, the only discs I have that are noticeably lighter are my Spondon ones and they aren't allowed.
Old 21-Mar-2005, 12:55   #13
fil2's Avatar
thats good feedback kev..........so no real weight advantage in changing then
Phil
Old 21-Mar-2005, 13:05   #14
The later OEM Brembo 320mm disks are 1.88Kg
I'll have to weigh an SS one and see what the difference is.
But, as I said, in terms of total percentage compared to a complete wheel and tyre it's not a big increase.
Old 21-Mar-2005, 14:20   #15
Bit heavier than Guido made them
http://217.199.188.40/xmb/viewthread...=5559#pid44098
Old 21-Mar-2005, 14:22   #16
Those are R disks, but I guess there shouldn't be any difference other than offset?
I was just going by the Brembo quoted weight rather than weighing them myself.
Old 21-Mar-2005, 14:23   #17
http://217.199.188.40/xmb/viewthread...=5910#pid47853
few more weights here.
I must put mine on the calibrated scales some time
Old 21-Mar-2005, 17:26   #18
Here ya go Fil - these are what you need ...
http://www.redracingparts.com/englis...iperbrembo.htm
Only €860 EACH! Mind you, are these allowed in the rules?
Old 21-Mar-2005, 17:35   #19
fil2's Avatar
Ali has those already...............dammit......................
phil
Old 21-Mar-2005, 18:40   #20
domski's Avatar
Is anyone going to be travelling fast enough to need brakes?
You're only trying to stop a 150kg lump from 100mph if you're very lucky, you don't need MotoGP style stoppers.
The CB500 had one disc, and weighed 180kg, and the brakes were plenty good enough to embarrass race reps on trackdays.
If you really want to spend money, do extra races... that'll make you faster.
2p
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 11:40.
