Old 06-May-2013, 21:26   #11
Chances are yours unlike the one in Antony's pic is loctited/thread locked in so its easier for the bolt and nut you are using comes out, this is why I use and Easy Out / Screw Extractor
Old 06-May-2013, 22:40   #12
Jonzi Jonzi is offline
Bikes: Monster 796, Class B 600ss
I am assuming this is like a drill bit?
I dont have power in my garage, so is there any other handtool i can get that can get these things out?
i might use a hammer.
Old 06-May-2013, 23:17   #13
No Dan
Its a hand tool, they normally fit into a tap wrench, but can be used with a good quality adjustable spanner as the ones I have have a a square end .
They are pretty much like a coarse thread left hand tap, lightly tap it into the end of the jammed bolt with a small hammer, put a spanner across the flats of the square end and turn anti clockwise, it will try and screw itself further into the cone but at some point the force required for it to go further in exceeds the force required to break the thread lock and starts unscrewing the stuck bolt. So No power required
I would recommend the tap wrench over a spanner
http://www.ebay.co.uk/itm/Engineers-...item3a7ef95c3b
Old 07-May-2013, 09:40   #14
Try it again using two nuts on the inserted bolt and lock them together.
Old 08-May-2013, 05:16   #15
badgerpilot's Avatar
Also try and get a blowtorch on the jammed bolt, the heat will break up the hardened Loctite/threadlock and make it easier to get out.
Scott #50
Old 08-May-2013, 10:56   #16
I bought the tools that Skidlids suggested.
Will take another bash at it this weekend.
If all else fails I am going to take a hammer to it.
Old 08-May-2013, 17:34   #17
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
If you're not going to be reattaching anything there, just drill the bolts out or angle grind them off. The only time you need to remove anything carefully, is if you need to refit it or something else in its place.
Old 08-May-2013, 17:35   #18
No power at the garage and too far to push the bike back home (and I don't own a van or trailer, I hire each time)
Old 08-May-2013, 22:06   #19
Time to consider one of these?
http://www.diy.com/nav/fix/power-too...skuId=12910116
Old 09-May-2013, 03:59   #20
Or one of these, can get them £50 cheaper if you shop around:-
http://www.ukhs.tv/Generators_2/Gene...rt-Generator_2
Scott #50
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 05:03.
