Old 21-Dec-2004, 22:39   #1
PHILLIP PHILLIP is offline
Mood: jolly chap
help advise on clutch
Hi all,
silly question here but can anyone tell me if the outside pressure clutch plate is meant to stop rotation once the clutch lever is pulled in, as mine stops and i dont think it should, if memory serves me right the whole clutch mechaniseme rotates all the time whether the clutch lever is in or out. Just removed my slipper clutch and fitted the standard one back on and cant remember it just dont look right !!!!
just thought i would ask before striping it all down again.
Thanks all
Old 21-Dec-2004, 22:46   #2
It can stop rotating, 'specially if it's a slipper or aftermarket item that isn't "toothed" to the drum.
However, it should slow fairly gradually. If it doesn't, check the bearing in the pressure plate is OK. If it's tight, then the cap could be rubbing on the pushrod or worse still spinning the pushrod in the slave cylinder.
Old 21-Dec-2004, 22:51   #3
Mood: me in a mood? NEVER!
yep it will stop cos think about it that is connected to the drive and if the bike isnt moving then it wont be turning but the inner will till you release the lever, how ever they both spin when in nuetral
Old 21-Dec-2004, 22:52   #4
Mood: jolly chap
Hi Nelly,
i heard you new your stuff !!! yes the clutch is a standard one and only done 3791 miles and just put it back on the bearings seems quite free and spins fine, it all seems to work fine although not road tested it yet,and as i said when the clutch lever is pulled in it slowly comes to a stop which i have never noticed until now and thought somethings wrong but if you say it,s meant to then fine, thanks again.
Phillip
OBBC
Old 21-Dec-2004, 22:54   #5
Mood: jolly chap
YEP SORRY LADS
" My lights are on but i,m not in "
Phill
Old 21-Dec-2004, 22:56   #6
ah ah dont be saying that near christmas or burglar bill will be in there!
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 07:12.
