Old 15-Nov-2005, 13:36   #1
dst1 dst1 is offline
dst1's Avatar
Mood: thrash the bitch
Chain cleaning
Can anyone suggest the best way to clean my chain,
will Petrol or Parafin damage the internals of the chain..?
The Chain will be off the Bike so should be easy.
Old 15-Nov-2005, 13:53   #2
BDG BDG is offline
BDG's Avatar
Don't use petrol, it will damage the o rings, parafin is OK.
Old 15-Nov-2005, 14:50   #3
WD40 and then relube with a light oil.
Old 15-Nov-2005, 15:33   #4
frazelli frazelli is offline
Mood: whatever!
I find parafin the best thing or sometimes use holts motorcycle degreaser which is in an aerosol if I'm feeling lazy!
Old 15-Nov-2005, 16:44   #5
Can anyone suggest the best way to clean my chain? Will Petrol or Parafin damage the internals of the chain? The Chain will be off the Bike so should be easy.
All motorcycle chains currently being manufactured use Buna-N (nitrile) rubber for their o-rings and x-rings, and all these manufacturers recommend kerosene (commonly called paraffin in the UK) as a cleaner.
Alternatively, you can use WD-40 that is composed of 80% Stoddard Solvent (that is similar to kerosene), 20% light lubricating oil, and a bit of fragrance.
WD-40, used as a one-step cleaner and lubricant is sufficient. Because it is a light oil, some fling-off will occur, so any excess should be wiped-off. USED REGULARLY, it provides good corrosion protection, low (but not the lowest) rolling resistance, and attracts less road grit than waxy chain lubes. So your chain stays very clean.
If you aren't inclined to clean and lube your chain regularly, or often ride in wet conditions that promote corrosion, there are chain lubes on the market that are designed to stick to your chain to resist fling-off and provide longer-lasting corrosion protection. Some remain tacky and attract grit, some stay slippery to the touch. All of them need to cleaned off and renewed at some point.
If you’ve decided to use chain lube after cleaning your chain, then it’s best to use straight kerosene as your cleaner because the light oil that WD-40 contains will make it difficult for the chain lube to stay attached without flinging-off.
Brake cleaner has been suggested to first remove the WD-40 but its effect on the o-ring seals may vary between brands, so I guess we're back to following the chain manufacturer's recommendation to use inexpensive kerosene as the cleaner.
Old 15-Nov-2005, 18:44   #6
ath748 ath748 is offline
ath748's Avatar
Mood: Missing my Flash...
WD40, then a little PTFE based lube, like the wife, then a spot of castrol wax. Chain always in good condition!!
Old 15-Nov-2005, 21:29   #7
dst1's Avatar
fantastic guys, can I presume you can get parafin at a DIY store, i have never bought it , the last time I saw parafin my Dad was using it in a heater to kept the Green house warm, I was about 12 years old then.
Old 15-Nov-2005, 21:33   #8
Rob B Rob B is offline
Rob B's Avatar
Mood: I'm so happyyyyyyyyyyyy
Get a gallon of parafin from many petrol stations.
Old 15-Nov-2005, 21:50   #9
dst1's Avatar
many thanks guys......
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:59.
