Old 03-Mar-2006, 20:06   #1
beek beek is offline
Front Brake Pipes
I have a choice of brake hose/pipes either the original 1 into 2 set up or using 2 seperate pipes.
1.....what is the better set up to use.
2..... if i go for the 2 seperate pipes how can i fix these so they dont clank around. the original has the clip on the mudgaurd to hold the hose how can i hold hoses
Old 03-Mar-2006, 20:43   #2
twpd twpd is offline
Deceased 02/10/2010 - R.I.P.
I don't know which layout has an advantage, if any but, I prefer the two separate lines. Fixing them in place is easy - buy some rubber lined p-clips from the likes of M&P or MPS. Fix the p-clips to the lower yoke. If it doesn't already have tapped holes you can do this yourself.
Old 03-Mar-2006, 21:01   #3
Lower yoke you say. i was a bit dubious of this as the yoke is hollow is this some thing youve done.
?? are you meaning just a small hole and self tapper. ? under yoke or front/ back
Old 03-Mar-2006, 21:27   #4
Nah...I did it on my SV650. I haven't looked at the SS yet but, I daresay it's not difficult. I used a 4.5mm drill and a battery powered drill. Then I tapped it out with a 5mm tap. If you're dubious about it then why not just use cable ties?
Old 03-Mar-2006, 21:45   #5
NBs996 NBs996 is offline
NBs996's Avatar
Mood: I love my 996 xxx
I'm to change to twin lines on the 996 but don't plan to secure them on the way up. I think they're stiff enough not to flap in the breeze aren't they?
Old 04-Mar-2006, 00:00   #6
Pretty much dude...it's that you need to worry about them flapping around - you need to pin them out of the way so that they don't rub against anything. Braided hose is quite abrasive and can do damage.
Old 04-Mar-2006, 00:09   #7
NBs996's Avatar
You're not wrong - I had a line on my blade rub a hole in the radiator!
Always careful with the routing now, and use lines with plastic wrap stuff on them.
[Edited on 4-3-2006 by NBs996]
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 09:34.
