Old 23-Feb-2014, 20:20   #1
Mykie916 Mykie916 is offline
Bikes: 98 916, 2006 Blade, DD Class B #20
Mykie916's Avatar
Numpty question
Taking small variables into account, what RPM will a 583 motor top out/redline/stop accelerating at? First track day today to test new bike and found myself changing up at around 8600 RPM or bike would feel like it's no longer making progress, midrange from about 4000 RPM she pulled like a train (not a big train but still a train ) does this seem about normal ? I'm more used to a screaming inline four, Myk
Old 23-Feb-2014, 20:42   #2
I always changed up a bit earlier than that on my Class B bike, If I dig out my old Dyno graph I will be able to tell you where peak power and peak torque were, but somebody currently racing Class B will probably be along soon and give you the info
Old 23-Feb-2014, 21:06   #3
Mykie916's Avatar
Thanks Kevin, felt unnaturally early to change up after the inline 4, in which case I'm really happy after my first day on the track, looking forward to brands
Old 23-Feb-2014, 21:47   #4
Campo Campo is offline
Bikes: Class B 600ss #99
Campo's Avatar
I use 8000rpm as a guide. Mine runs out of steam about then
Old 24-Feb-2014, 13:00   #5
coppersaucepipe coppersaucepipe is offline
Bikes: YZF750R, DD 'B' class monster #2
8200
Old 24-Feb-2014, 22:00   #6
badgerpilot's Avatar
Roughly 8250, with a good boot up the box you should still be 7750ish in the next gear and pulling again.
Scott #50
Old 25-Feb-2014, 00:11   #7
Trumpet Trumpet is offline
Bikes: Triumph Speed Triple/DD 620/
Mood: It's a grand life if you don't weaken
Had two different 600ss bikes on dyno, they both similar, and seem to make maximum power around 7400rpm it stays flatish to around 7800rpm then power starts to drop off. But the feel is nearer to what everyone else is saying, about 8000.
Old 25-Feb-2014, 00:29   #8
Bimjob Bimjob is offline
Bikes: Yamaha R1, Ducati 600SS
I had only ever ridden in line fours pre DD and it took a bit of getting used to at first but you soon learn to ride the low down torque. Also if you've got standard igniters then I think they limit the revs to about 9k anyway
Old 25-Feb-2014, 22:51   #9
Mykie916's Avatar
Taking bike to seastar superbikes on Saturday to have bike checked on rolling road, anyone know if I can set up a shift light easily, bike has a mychron 3 dash, only thing connected to it is the pulse lead for reading the RPM and a lead with a white 4 pin square pin plug don't know what that bits for, Myk
Powered by vBulletin 3.5.4 - Copyright © 2000 - 2026, Jelsoft Enterprises Ltd. - © Ducati Sporting Club UK - All times are GMT +1. The time now is 19:45.
